How to install the Rollercoaster Tycoon Deluxe
I am receiving the error message “Enter disk 0 that contains the file Data3.cap” while trying to install the Rollercoaster Tycoon Deluxe I game. How can I overcome the issue and install the game successfully?
Answered By 5 points N/A #106841
Is the error occurring when you try to install that game only or it is occurring when you try to install other applications too? You will also need to check and verify that the CD-ROMS that you are using for the installation are legit, check if they are scratched for that may be preventing the DVD drive to read the data from the disk. When CDs are scratched, they might be missing some files, as well CDs that have been copied.
So if you had copied that CD and it is not an original, I will suggest that you get the original copy of that CD and use it for installation and see if the problem will be resolved.
-Chalk Talk
Answered By 590495 points N/A #287181
If you are installing the game “RollerCoaster Tycoon: Deluxe” and you get that message, that means the installer you used has a problem. It is maybe damaged because you downloaded it from another non-official website. I have encountered this error a lot before when installing and the most common cause is an incomplete installer.
This happens most of the time if the installer has been compressed into multi-volume archive probably so it can be stored in a floppy disk. There is actually no solution to this because most of the time it is caused by a modified installer. If you really want to install the game, download it from the official website: RollerCoaster Tycoon: Deluxe.
RollerCoaster Tycoon: Deluxe is a simulation game developed by Chris Sawyer Productions and published by Atari released on March 31, 1999. It supports Windows XP and Windows Vista and requires 1.8 GHz or faster processor, 512 MB RAM, Microsoft DirectX 7-compatible video card, sound card, and 2 GB hard drive space.
