How to install runes font for office? I just downloaded a rune font but the installation process didn’t go through for some compatibility reasons. My operating system is windows xp, would you like to share some possible solution? I need some guidance along the process.
Waiting for your support, thank you.
tipper03
Hi Stephen,
In order for you to use the font you need to add the font in your computer.
To add new font
1.) Click Start then open the Control Panel
2.) Go to the Appearance and Themes and click the Fonts under in the See Also.
3.) In Fonts Folder, choose the File in the menu bar then select Install New Font.
4.) A new window will appear which you have to locate the font you want to install.
5.) If you locate the font, select the font and click Ok.
6.) Wait for the font installation to finish.
7.) Then open your office and just select the font you just installed.
I hope this information helps you.
