Hi, currently I am using Samsung galaxy tab. However, I am facing a problem on my tab. My software's are not automatically updated.
Can anyone suggest me how I can get rid of this problem?
How I can install Samsung galaxy tab software update?
How to install Samsung Galaxy tab software updater ?
I will suggest you use the FOTA (Firmware Over-the Air), there has feature for Software Update. For the Samsung Galaxy Tab UT-P7300 FOTA User. Please show you on how to Upgrade.
Steps
1. Sign-in to Google Account
2. Click Settings + About device + Software Update then select a. Auto update (must check for new regular updates), b. WiFi only (If it is unchecked software will be upgraded through your mobile software). c. Push messages (must check for updates/notifications to your IOS device.
3. If you notice New Software check this and click OK. Choose which one of the two networks you're using: mobile network or WiFi connection.
4. Wait for the installation then click finish. If the software prompts you to reboot your device then do so for the complete installation.
Note: Full reset your device by going to Setting > Privacy > Factory Data reset >Select reset device. Most importantly, Do not skip procedure to sign in Samsung and Google account because it's a requirement before proceeding steps.
Hope this works.
Steele Ney
