How To Install A Second Monitor Through Different Ways?
With the growing technology, we are new ways of our comfort. We can use monitor screen as a television too. How to install a second monitor?
We can use multiple monitors together for our convenience. We can use second display as extra desktop. We can also switch between monitor and television.
Method 1:
Step 1: See the plugging of the monitor. If the connection is horizontal, then it is connected to the graphic card.
Step 2: Make sure both the connection needs to be attach with the same graphic card.
Step 3: Determine the available ports using the Graphic card. On the basis of it, you can connect your monitors.
Step 4: HDMI- It helps in transferring sound and image in the best quality way. VGA- It has an analog output. DisplayPort- It is for 4K display. It is a digital connection.
Step 5: Attach your second monitor by doing power down of your computer.
Step 6: After right clicking on the desktop, choose Properties and then Settings and then Multiple Displays.
Step 7: You can choose several options such as Primary Only, Second Only, etc and can switch between the screens by pressing Windows key+P.
Method 2: For Mac.
Step 1: Buy adapters in order to connect new monitors to old computer and also check the available ports.
Step 2: For connecting, power down your Mac.
Step 3: Choose Apple menu and then System Preferences then Displays and then finally Arrangement tab.
Step 4: You need to select a resolution that works on both the monitor.
