How to install Sky go app on rooted Asus Padfone?
I installed this app as I have an active sky connection at home but it won't work, it says my phone is rooted. Is there any way I could make Skygo work on my Asus Padfone Android 4.0 (ICS)?
Sky Go will not work in your Asus Padfone 4.0.Â
The following are devices that are compatible with Sky Go Application are:
Galaxy Note I,II and III
Galaxy S II and III
If you have any one of these gadget then you might want to install Sky Go there. To do this, first you need to register on their official website. After registration, you must sign-up on this page to enable your Smartphone with Sky Go. Once you have logged-in, you can install your application to your phone by connecting it with the account code that will be emailed to you.Â
Taylor
