How to Install Skype on BlackBerry Tab?
I am used to the BlackBerry system software. I want to use Skype how it will download in free for BlackBerry tab?
Hi Mohabbat114,
First you have to download Blackberry App Store into your device and create an account. After which, you can find "Skype" from the Blackberry App Store and download it. AFter downloading, install it and you may now sign in with your Skype account and start using it.Â
Hope this helps! Thank you and Enjoy!
Hi Mohabbat114,
If you are using BlackBerry phone you can get Skype provided your mobile partner should support Skype. But unfortunately BlackBerry Playbook does not support Skype. They have their own video chat application through that you can stay connected with your friends. If you are a mobile phone user you can download it directly from Skype site. Honestly you cannot use Skype in Blackberry playbook.
Thanks!
