How To Install A Smart Card Reader With Different Methods?
One of my friends works in an office where he is the security in charge. He is planning to use a card reader. How to install a smart card reader?
Smart card readers help in performing the transaction and obtaining the card information. We need to insert the card into the reader, and it requires a physical connection.
Method 1:
Step 1: Go to Start, and then in Search programs and files box, enter Device Manager.
Step 2: Press Enter.
Step 3: You can see the smart card device in the list by double-clicking Smart card readers in the console tree.
Method 2: Manually installing it.
Step 2: Press Enter
Step 3: Select Browse my computer.
Step 4: You can see the smart card device in the list by double-clicking Smart card readers node.
