How to install Smilies in Linux Ubuntu ?
Dear Experts,
I am a user of Linux-Ubuntu.
I have heard that we can install Smilies for Linux powered by VBulletin.
Want to install vbulletin Linux Smilies.
Can anyone help me find them?
Dear Experts,
Hi there,
The whole thing is easy to install and work with Linux operating system.
Just download the package of the vBulletin Smilies and install them by
sudo apt-get install (the package file path)
Now once the package is installed then open the GUI of the vBulletin and change the Smilies category into generic.
Now you can use it for adding new Smilies.
I hope this would help you to solve your problem.
Best regards,
Riley Weaver.
It is easy to install the Smilies in vbulletin Linux Smilies.
Find the easy steps as mentioned below :
In GUI Mode : Linux- Ubuntu
1. Go to Admin Control Panel of vbulletin then Select the vbulletin Smilies from the sidebar.
2. In the Smilies Option : You can find three Options
   a. Smilies Manager : To manage the Smilies
   b. Add New Smilies : To Add new smiles
   c. Upload Smilies : To Upload and Manage the new Smilies.
3. Use Upload smilies to Upload the New smilies to vbulletin. You can also even from the local computer.
4. Now it is almost done and you have successfully used the Smilies in generic mode.
In Command Mode : Linux – Ubuntu
1. You must have the root access or sudo access to install the package.
2. Download the package of Smilies from vbulletin.com members area.
3. Upload it to vbulliten admin control panel to vbulliten smilies or else
Use the below command as
For Linux it is : yum install <package name>
For Ubuntu it is : apt-get install <package name>
Then it is almost done. Browse the smilies from vbulletin and It is ready to use the smilies.
Congrats you have done it successfully.
Noel Sammy.
