Hi, I recently installed the software named Ninite. It helps to install the software automatically. But I don’t have a proper idea about this software. How its help us to install the software automatically? And What are the advantages and disadvantages of this software?
How to install the software automatically
Hi JohnJValentine,
It is very helpful software for all types of user. Daily we install and update many software but if you use “Ninite” software at the desktop then you have no need install the update manually. You should choose from its directory which software you should keep “up to date”. It is very simple tool for Windows operating system.
How it will work?
You should run the exe file of Ninite and go to its directory to choose your desirable software which you want to keep “Up to date”. Then it will be starting its work silently.
Just like-
What's the advantages-
· It works silently
· Never update harmful files
· You should not think about software (like Flash player, Adobe reader etc.) update.
What's the Disadvantages-
· Sometime it will give pop up message for “Foxit reader”
Good luck
Hello JohnJValentine,
Thanks for your question. Ninite is a very helpful software if you get too boring to install all the software you want. You can avoid the installation process of your required software with just a few clicks. It's a kind of software database. You can find almost every software you need on there. You just have to go to their official website which is https://ninite.com/. Then you can select the required application of your choice by clicking the checkboxes and download the ninite installer. Ninite downloads and installs everything you need and also skip the unnecessary part included in the product such as toolbar, advertisement etc. Also you can keep your software up to date by ninite. Some of the tools in there are shareware which means if you want to get the full features of that tool you have to buy it. Hope it will help. Thank you.
