How to install some hello kitty microsoft themes? I am using windows 7 64 bit operating system in my Toshiba laptop. I already downloaded a hello kitty theme and very excited to apply it. I just want to know if where did the download was located and also guide me on the proper installation process.
Waiting for your support, thank you.
How to install some hello kitty Microsoft themes?
Dear user,
Hello kitty cartoon character is no doubt one of the most favourite cartoon characters of girls. For downloading its themes, what you need to do is open this website http://www.dl4all.com/ell/tag/hello+kitty+theme+for+windows+7+starter.html, Click on hello kitty themes for windows 7 starter (trusted download), a dialog box will open, click on save file, open the folder in which the downloading is done, double click on hello kitty themes for windows 7 starter, click on download button on the fast download dialog box, choose the location in which you want it to be downloaded, it will start to download. The website also provides a way to download the themes.
Thank you.
Hi there,
Actually I don’t install themes in Microsoft Windows 7 64 bit. But here are the steps you can do:
First download the theme you desire, it must be a Windows Theme file
Then, copy the file and paste it to this path, C:WindowsResourcesThemes.
But you can find some themes that need to be installed. If it is the case then just run it as administrator and follow the installation process.
You can find your downloaded files in the Downloads Folder.
That’s all. Enjoy.
