Hi guys,
How to install Sony vaio light scribe driver? Give me some tips on the proper installation process of Sony vaio light scribe driver. I don’t want to compromise the laptop’s security. I just need to install it properly to avoid future problems.
Expecting some help, thank you.
How to install sony vaio lightscribe driver?
Hi, Go to Sony’s support resources. Now hit detect my Model and this under the auto detect or you can select your product category. Now select option 3 and hit continue. In this case detect model option may not run for specific computers. So you can hit how do I select my model no. and when the download is complete you will have to follow the proper instructions to complete the driver installation.
Sometimes you have to click next and continue and accept the agreement to finish the installation.
Unfortunately, Sony Vaio does not come with support for lightscribe. Most likely what you have there is a standard DVD SuperMulti Drive. This means that even though if you would be able to install lightscribe driver software, it would end not working at all.
If you insist of having lightscribe, the better option is to get an external optical drive that comes with lightscribe support.
Hi Kristen,
All you have to do is insert the CD / DVD in your CD / DVD Drive, if you have one. If you don’t have the CD / DVD, download the installer by going to the Sony website, Support, then Downloads.
Run the installer, read the instructions and you will be asked to select the Language, click if you agree to the Terms and Conditions, then click Next throughout the installation and Finish.
Hi Kristen,
There is no Installation for Sony vaio. You can download it here:
Just add your model number, and download
https://www.sony.co.in/electronics/support
You can download,install and Run Malwarebytes Anti-Malware here:
You can reinstall sony VAIO But it will erase everything that you have saved onto the hard drive.
