How to install sound card driver 98
Hello, I have installed windows 98 for an old machine to know about the windows features on that time. But after installing sound card driver 98 for that PC it still I cannot hear the sound. Can you explain me what was its problem?
Answered By 30 points N/A #134192
Thank you for your question!
For some computers with newer sound cards, you can have issues if you install an older version of windows like Windows 98, you can go with your computer on that site: https://www.touslesdrivers.com/ , and click “Mes drivers”, then "lancer la detection", it will ask you to install a plug in to scan your computer for compatible drivers for your sound card, also, you can provide us with the exact model of your computer and your sound card and we can check available drivers for you.
