How to install srs premium sound drivers win7? Windows 7 is a sensitive operating system and always asking permission in the administrator to allow things to be installed. I just want to ask you on the proper process of the installation. I need some help.
Kimberly Walker.
Hi Kimberly
You want to install SRS Premium Sound Driver for Windows 7, and you have to download the compatible driver for your system model. I don’t know which model you are using that why I suggest you to download the driver from your laptop company's websites. Here I am also giving you link for SRS Premium Sound Driver for windows 7 but i am not sure this will be compatible or not with your system.
After download, Right Click on Driver and Select "Run As Administrator" and follow the instructions.
And yeah Windows 7 always asking for permission to allow the program and this is great feature of windows 7 because it secures our system to unwanted programs and virus activities.
Hi Kimberly,
The installation process is still the same. All you need to do is to read the instructions and click on the buttons that will navigate you to the next step.
You should also check if you downloaded the right version for your Operating System.
Windows 7 and Windows 8 ask for the administrator's permission first before installing any software and applications because it will make changes that will affect everyone who uses the computer.
