How to install thunderbird icon Mac?
Hello experts,
How to install thunderbird icon mac? My mac operating system is not that easy to use for I am confused on some settings and the way it is set up. However I need your help on the installation process of thunderbird icon on my operating system. I hope you can give the best advice and suggestion.
Thank you.
Answered By 0 points N/A #186061
How to install Thunderbird on a Mac OS?
Below are the steps to install Mozilla Thunderbird on Mac OS:
1.   Download the installation file
        a.) Download the installer at Mozilla Thunderbird Download site.
        b.) Under the Thunderbird Free Download button, click on “Other Systems & Languages”
        c.) Choose under Mac OS X and your preferred language.
        d.) Click the download link. Wait for the download to take place.
2.  Start the installation process
      a.) Double click the thunderbird.dmg icon
      b.) Drag the thunderbird icon to the applications folder.
3. Start using Mozilla Thunderbird Email Application
      a.) Open the applications folder and double-click on the icon
      b.) Launching the application for the first time, an Account Wizard will guide you.
