How to install the Toshiba NB205 netbook default OS?
Gerald 0 points N/APosted on - 08/14/2011
All please help. I have a Toshiba NB205 notebook. I like to reinstall, which I know in the NB205 OS XP default. How to install it? He said there is a special button on the keyboard to directly install the Windows default or there may be another way?
If you have a Toshiba laptop and you want to reinstall the default operating system or the version of Microsoft Windows that came with the machine, you need to have the Windows XP setup CD to reinstall the operating system. Laptops don’t normally come with a setup CD of Microsoft Windows because the operating system that comes with the machine is for promotional purposes only.
Toshiba NB205 mini laptop
It comes as a package. That’s why if you want to reinstall it, you have to buy the license for the operating system because there is no downloadable version of the OEM version of Windows XP or any OEM version of Microsoft Windows. Now, to get the complete list of drivers for your laptop, you can download it from the manufacturer’s website.
For Toshiba, go to Toshiba Support. Here, enter your laptop’s model number or serial number. You can find it printed on the side or bottom of the machine. Enter the correct version of your laptop because there are many versions of Toshiba NB205 like for example without quotes “Toshiba NB205-N210”. Once you located your laptop’s version, select your correct operating system.
Go to “Drivers & Updates” tab then download and install all available drivers and software for your machine.
Early Life and Career
Tailleur Elisabetta Franchi ardour for style started at a young age. Growing up in Bologna, she continually had a keen interest in design, regularly sketching her ideas for garb. After finishing...
1....
