How to install total video converter for nokia 603
Hello expert,
I have Nokia 603 mobile. I know the best converter is a total video converter. So I need to install total video converter for nokia 603. I have never installed this software to my mobile. So I want to know how to install it correctly. Please tell me how to install it properly. I should be glad if you can give me the links with the answer. Thank you.
Answered By 30 points N/A #199411
Hi Dear Karengsam,
It is much easy to install total video converter to your mobile phone.
You have to do some steps as I say.
1. Download total video converter in your mobile phone or copy from other source. It will be in java application.
2. Open it in mobile phone by simply clicking the center button of navigation keys on the phone.
3. It will start installation process but at 35% it will ask you where to install it. In phone memory or in Memory Card.
4. Choose your desired place here. Memory card will be better for you.
Then click on continue. Now it will take one or two minutes and your application will be installed.
I hope you got the answer. Here is a link to get more information.
More Information.
Thanks
