How To Install TP Link Wi-Fi Router Full Details?
I am an employee in the IT Company. I have come across a new device TP link Wi-Fi router. How to install TP link Wi-Fi router and what are the advanced preparations?
You need to turn off your system, modem, and router. With the help of Ethernet cable, connect the modem to the WAN port of the TP-LINK of the router and also TP-LINK router’s LAN port to the computer.
Step 1: Go to router’s web-based management and log in.
Step 2: Select Network then WAN and change the WAN connection type to PPPoE.
Step 3: Enter the username and password.
Step 4: The internet will connect after a when you click Save.
Step 5: Check for the WAN part of the status page and if you see IP address, then there is a connection between router and modem.
Step 6: If there is no link as well as IP address then turn off the DSL modem, and then router and computer for few minutes. Then ON then and start the process.
