How to install Trillian pro Symbian? I have the older version but now that there are some latest version over the internet can you give me the best advice on what version to get and the compatibility measures. There are some cases that the download is not secure how will I be sure that there are no data that might harm the system.
Thank you.
How to install trillian pro Symbian?
For what Symbian version? I think it supports Symbian 1 and 2.
Trillian is a multi-network chat client. It supports all of the features you've come to expect from a good IM client. It is completely free with no built-in ads. I have given you a link below that will let you download it. Just make sure to run a virus check before you open it, though I’m sure it is fine.
By the way you can check the official website for trillion for updates and versions.
Thank you.
