How to install ubuntu Linux?
Asked By 7060 points N/A Posted on -
Hi all,
There is a question. How to install Ubuntu 10.10 on flash drive.
I have flash drive 4 GB.
Can anyone help me please.
Thanks in advance.
Best Answer by Jahid Hasan
Answered By 0 points N/A #79347
First, you need to download Ubuntu Linux 10.10 from Ubuntu official website. It will downloaded in your harddisk in ISO file format. Then you'll have two way of choice to install Linux Ubuntu 10.10 on your PC. First choice is you can install by making a bootable CD. For that, you have to burn this ISO file into a cd by using a burning soft. Which support ISO file format for burning the CD.
Then you will ready to install you Ubuntu 10.10 from the bootable cd. When the installation in going on you will see it mentions a path where you want to keep the operating system. Then all of you have to do, just mention the path as your flash drive.
Then complete the installation. Hope it will help.
Answered By 0 points N/A #79348
This is a common problem with Ubuntu and you've got to be careful as you follow these instructions;
Just Insert the 2 GB USB, select your flavour you want to install (probably i386 10.10) and point it towards the .iso you have downloaded. Make persistent by checking the box (will allow saving of programs/ changes).
Edit: FYI you will still be prompted to either try or fully install. It doesn't add much time on other than if you wanted to switch on the pc and go make a cup of tea. Then it will just wait for you to select an option rather than just boot to the desktop.
Answered By 0 points N/A #79350
You will need the ubuntu 10.10. ISO image that corresponds to your hardware architecture (i386 or amd64), and that can be downloaded from https://www.ubuntu.com/. When the download is over, burn the ISO image with your favourite CD/DVD burning application (Nero, CDBurnerXP, Roxio) on a blank CD at 8x speed.
Reinsert or leave the CD in your CD/DVD-ROM device and reboot the computer in order to boot from the CD. Hit the F8, F11 or F12 key (depending on your BIOS) to select the CD/DVD-ROM as the boot device. Wait for the CD to loading. In a couple of minutes you will see the wallpaper and the installation wizard. Select your language and click the "Install Ubuntu" button to continue.
Answered By 0 points N/A #79349
At first you go to https://www.ubuntu.com/download/desktop
For download Ubuntu 10.10 ISO file:
Then go to https://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
  • For download Universal USB installer.
  • Then start the Universal USB installer.
Step 1: Select the Ubuntu Version 10.10
Step 2: Select the Ubuntu ISO File.
Step 3: Select the USB Pen drive then click Create button.
  • Then after completing click Close button for close the Universal USB Installer.
  • Then restart your computer and boot from USB flash Drive and.
  • Complete your installation Ubuntu from USB Pen Drive.
Answered By 0 points N/A #79352
I am writing the procedure in steps,
1. You must have an UBUNTU disk.
2. Start Install process.
3. Prepare disk space and guide the path. (USB).
4. Now wait till the UBUNTU work on installation files.
5. After installation put off the disk from the ROM and restart the computer.
6. From the BIOS menu choose boot from USB and the window will come in front of you.
7. You should have a minimum flash drive of at least 2 GB or 4 GB recommended.
Using these steps you can easily install the UBUNTU in your flash drive and can access from any PC.
Answered By 0 points N/A #79353
How to install Ubuntu Linux on a flash drive:
  • If you want to do updates and upgrades you should do a "Full" install to the flash drive.
  • Is your ISO install even persistent? I mean does it save changes?
  • I think the ISO file is frozen and not easily modified, you cannot upgrade the kernel.
  • You can make a ISO install persistent using a persistent partition, (casper-rw) or with a persistence file by the same name.
  • For a 16 GB flash drive I would suggest the "Full" install.
  • Disable your internal HDD insert the Live CD, plug in the flash drive and run install after booting.
  • Use manual partitioning to keep a FAT32 partition as your first partition so you can save stuff to it from a Windows computer.
Answered By 0 points N/A #79354
Following is the step by step full installation of Ubuntu Linux on your flash drive
1:  At first “Switch off” and “Unplug” your computer.
2: Second step is the removal of the sides of the case.
3: “Unplug” power cable from the hard drive.
4: Fully “Plug” the computer now.
5: the next step is the insertion of flash drive in your system.
6: Insert the Live CD in your CD/ DVD ROM.
7: Then start your computer and let the CD to boot.
8: Pick your appropriate Language.
9: Select “Install Ubuntu Linux 10.4”.
10: Complete the process of “Time Zone” and “Keyboard Layout”.
11: At ""Prepare Disk Space"" you need to select ""Specify partitions manually (advanced)"".
12: Then you have to select ""New Partition Table"", and click “Continue” on the drop down.
13: Then click ""Free space"" and “Add”.
14: Choose “Primary” then.
15: Then you have to formulate “""New partition size"" round about 1gb.
16: Location = Beginning.
17: Use As: = ""FAT32 file system"".
18: ""Mount point"" = windows.
19: Choose “OK”.
20: By clicking “Free Space” and then “Add”.
21: Choose ""Primary"", ""New partition size"" = 3 to 4 GB, Beginning, Ext4, and Mount point = ""/"" and then “Ok”.
22: Optional.
23:  Then click ""Free space"" and “Add”.
24: Choose ""Primary"", ""New partition size …"" = 1 to 2 GB, Beginning, Ext2, and Mount point = ""/home"" then OK. (Optional).
25: Then click ""Free space"" and “Add”.
26: Choose ""Primary"", ""New partition size …"" = Remaining space, (1 to 2 GB), Beginning and ""Use as"" = ""swap area"" then “OK”.
27: Then by clicking “Forward”.
28: Then by inserting your name, username, password, personal computer name and then you have to select either you log in automatically  or required any password.
29: Choose “Forward” then.
30: Choose “Install”.
31: Then you have to wait for some time until installation completed.
32: Then Switch Off your PC and “plug” in the HDD.
33: Finally you have to stick back the side panel on.
Answered By 0 points N/A #79355
I am Raisa. Here is your solution. For installing Ubuntu 10.10 you need follow this process.
First you have to install UNetbootin in Windows or Linux Systems. You can download from this. Here is the link:
After installing now its time to choose distribution and continue. Then you need to select the USB drive and click OK.
You should wait for some time for the download to complete.
Then click Exit. After that, Remove the USB Drive and insert it into the PC without CD/DVD drive and boot from it.
Then You have to configure your computer to boot from Removable devices. Then press the F-2 or Esc on the keyboard when your computer is booting up. UNetbooyin should automatically boot and begin installing Ubuntu.
Then login to Ubuntu and run click 'Install Ubuntu 10.10" to continue.
You need to just follow the step.
Answered By 0 points N/A #79356
 If install Ubuntu 10.10 on portable flash drive you can installed it in the recommender way that the website instructed you to do (using USB universal installer).
But Ubuntu is having trouble in the main menu where it freezes when it ask you "try Ubuntu first or install Ubuntu".
You have to go through this window every time Ubuntu boots from your flash disk and it literally adds 20 minutes to the boot time.
Answered By 0 points N/A #79357
Get unetbootin from Ubuntu's website.
Select the ISO from your hard drive then reboot and boot from USB! Voila!
Read more here.
Answered By 0 points N/A #79358
You should have at least a 8 GB flash drive, but it can be installed in 4 GB but you will be constantly housecleaning and cannot load very much additional software.
Grub will default to installing to the sda MBR, you have to use manual partitioning and choose where to install the boot loader.
It does not have to be encrypted:
Standard full install to flash or SSD:
More discussion Dec 2010:
Use ext2 or ext4 without journal:
Tune2fs -O ^has_journal /dev/sda1
No swap or set swappiness
After installing, change the fstab so that everything gets mounted with noatime.
Change to noop i/o scheduler
You want journal to speed up system recovery if you have to do repairs or run fsck. But if partition is small then it does not take long to fsck anyway and without journal writing is reduced.
Hope it can help.
Answered By 0 points N/A #79359
In order to install Ubuntu Linux on your flash drive, please take the following steps for the installation. In order to download Ubuntu Linux, you need to select the download option, afterwards it will ask few questions, you need to use the required and appropriate tabs which will appear at the top of the page.  The second step is selecting the country name, country server name after the drop down list will be appearing. Please select the most appropriate server with the fast downloading speed for you.  You need to pick either 32 or 64 bit Unbent and viola at the box.
When an installation disc is downloaded into the format ISO which is very easy and convenient to write and burn to disk later. But it depends on your connection speed, then maybe you should wait a few minutes, but if you have a good broadband connection, it will take less time .
Now we are almost completed the setup and installation. Now we can download ISO Recorder. This is freeware software, then inserts a blank CD or DVD into the drive and locates the Ubuntu ISO on your hard disk using ISO Recorder. It must not take long time to download and when its downloaded you just need to click the option “Burn”. If you have the drive to be ready, put it in the drive and restart the computer.
Go into the BIOS and do set your PC to boot from the CD before the hard drive. Once this is installed, save the settings and restarts the computer for the last time. The last step is to download the “Graphical installer” that will be loaded from the CD and the system will then guide you step by step all the ways to confirm that you have all the necessary drivers and software before you are ready to go, and now you that you have the pleasure to spend time with Ubuntu Linux.
Answered By 0 points N/A #79360
I give the system below,
  • Download the universal USB installer.
  • Clicking on Run.
  • Read the license agreement and choose 'I Agree' to continue.
  • Select Ubuntu Desktop Edition from the dropdown list.
  • Click 'Browse' and open the downloaded ISO file.
  • Choose the USB drive and click 'Create'.
It may be helpful for you.
Answered By 0 points N/A #79361
For installing Ubuntu, you need to install 1.8.5.7 version of the USB installer program and do not update this installer by Sunday (10/10/10).
You can install Ubuntu 10.10 Linux easily by following certain steps.
1: For installing Ubuntu Linux 10.10, you must visit the following site for downloading purposes. https://www.pendrivelinux.com/
2: You need to click this link in order to download Ubuntu 10.10 Linux, and then you need to update the Universal USB Installer – Easy as 1 2 3.
3: There exists an option of “Download” in the end of this page named (Universal USB Installer 1.8.5.7.exe). You just need to click the download option and after a few seconds your downloading will start.
4: After the completion of downloading, you have to accept the agreement.
5: afterward you need to select Ubuntu Linux 10.10
6: When you're downloading has completed, you just Browse to and select the ISO.
7: You need to select the name of your USB flash drive only.
After completing these steps, you just have to follow certain instructions and then create it. You need to make determined by checking the box (allowing the programs to be saved or make any changes further).
You will be impelled either to try or full install option.
There exists a case if you have downloaded the corrupted ISO, this problem will be fixed by simply re-downloading the ISO and follow the above mentioned steps.
