Hello experts,
How to install vb6 bulgarian font? I got my vb6 installed in my windows 7 64 bit operating system and I want to make a secure installation process. However I don’t know how to apply or put the Bulgarian font in vb6? I need to use it for my project. Thank you.
Hi HERNANDEZ,
I have read your problem. There is a way. You have to use AddFontResource for this purpose.
1) First copy your specific font into %windir% font’s folder.
2) Use Addfontresource or AddfontresourceEx to add that vary font.
The font will be available before reboot.
If you just copy the specific font into the %windir% font’s folder then you will only be able to use this vary font after the system is rebooted.
This should remove your problem.
