How to install VLC for firefox Mac.
Hello…,
You can download it from the video Lan web site,
Simply to the site and select the necessary program and the Operating system that you’re using.
However video Lan haven’t released a newer version for it, and that is version 0.9
You can download the old version and that is 0.8.
No matter the version it still works perfectly for the browser.
VLC is one of the most popular media players. It automatically installs web plug-in while media player is installed. Just download VLC Media Player from http://www.videolan.org/ and just install. Then go to add-ons>plug-in and there you will see that VLC Web Plug-in is installed. VLC is available for Mac so this system will also work on your Mac.
