How to install the VLC os x lion heats
Hi
I am using the mac OS x lion in my PC. There are some problems when going to play videos in my PC. So I need to install vlc player in to my mac OS. How can I do that?
Hi
Hi Kevin Moiles,
There’s a lot of site out there where you can download VLC for Mac OS, you can try this sites:
Download latest VLC for Mac OS X 10.5 and later
Or you may try this in case the first two don’t work:
Kevin,
In order to install VLC on your Mac follow these steps:
First: Download the Mac OS X package. You can do this from the VLC Mac OS X download page.
Second: Double-click on the icon of the package. (There should be an icon on your desktop right beside your drives.)
Third: Once the icon has opened, drag and drop the VLC application to the place where you want to install it. (It should be showing /Applications).
