Hi to everyone,
How to install vlc for Samsung led? I need a vlc player for my Samsung led series. Can you show me the way or any illustration that will help me to get a successful and compatible error free installation? I just need it for movie viewing.
Thank you.
How to install VLC for Samsung led?
Get your copy of vlc player for your Samsung led series on this site http://mobile.afreecodec.com/vlc-remote-free-87743.html?o=keywords. VLC Remote allows you to sit back and enjoy your music and movies at the same time as you organize things from your couch. We provide free setup helper just to configure VLC and unite your Android in just two button clicks.
Best regards,
Heather marie
  If you want to install VLC Samsung led player I have mentioned points below:
1- First you must complete save all files of VLC player setup.Â
2- Go to run option and run setup.
3- After completing the setup.
4- Go to tool options.
5- Configure VLC application.
6- It will give you pop up for updates you must update for this application.
7- Click on finish button and use VLC.
Thanks
Raun Nelson
