Dear Techyv members. I need help on how to install Vnc smart card authentication effectively. I need the highest level of security for my data base. How can i secure this? What are the steps needed for a successful Vnc smart card authentication? I would also like to hear opinions, answers, and solutions from veteran experts in terms of online security.
How to install vnc smart card authentication effectively?
Hello Ruthprobertson,
As far as the matter of securing the servers or databases with vnc smart card goes, you should be the one to choose what type of security you want for your database as you are the only one who could calculate what level of security you want. There are a number of measures and products available in the online market to choose from.
But I can suggest you some provisions that you could apply with whatever protection measure you install, to increase security level.
Keep the authentication credentials secret (only a few people should know about them).
Deploy group policies to limit access.
Restrict software access (allow only the ones you trust and keep the number to a minimum).
I understand your concern about the security for your database which we all know it contains delicate information.
I can give you a set of instructions on how to effectively install the VNC Smartcard Logon Plugin which are all indicated in a PDF file.
You can download the PDF file or view it on Google Chrome browser here.
The steps are user friendly so it is very easy to understand.
