How to install wamp server 64 bit
Hello !
I don't know how to install wamp server 64 bit on laptop. I want to install it please provide tips about wamp server installation process.
Hello !
I have read your problem and a best solution for your problem which I will recommend you is,
I have given a link for you. I am sure this will be guiding you to install your wamp server on 64 bit.
The link is:
http://www.tutorialchip.com/php/wamp-server-installation-guide-for-windows-7-3264-bits/
This link has a step by step guideline for you to help you to install the wamp server as per your 64 bit operating system. I have also refer you that you only need what kind of system and what kind of version helps you to get your required result.
Hope so you will get the solution from my suggestion.
Good luck for your future working.
Because WampServer is available in 32-bit and 64-bit versions, make sure you download the appropriate version for your computer. If you are running 32-bit Microsoft Windows, you need to install the 32-bit WampServer. And if you have x64 Microsoft Windows, you need to install the 64-bit WampServer and don’t try installing the x86 version to avoid any issues though x64 Microsoft Windows can install x86 applications by running them in 32-bit compatibility mode.
Installing WampServer is very easy. Once the installer is downloaded, just double-click on the downloaded setup file and the rest is automatic. You just need to follow what is stated in the instructions to complete the installation process. If you have the old version of WampServer, you need to have the latest version.
Download WampServer 2.5. Both 32-bit and 64-bit versions include PHP 5.5. It supports Windows Vista Service Pack 2, Windows 7 Service Pack 1, Windows 8, and Windows 8.1. For servers, it supports Windows Server 2008 R2 Service Pack 1, Windows Server 2012, and Windows Server 2012 R2. Because WampServer 2.5 is written using VC11 or using Microsoft Visual Studio 2012, you need to install Visual C++ Redistributable for Visual Studio 2012.
WampServer 2.5 is not compatible with Windows XP and Windows Server 2003. Also, don’t install any new release of WampServer over an existing installation or similar when upgrading an application. Visit Installing New Release Of WampServer to learn the guidelines.
