How to install wampserver in my Windows OS
Hi all,
I have to install WAMP server in my PC. I have Windows XP and I don't know how to install it could you help me ?
Hi all,
Hi bob42,
What you have to do to install the WAMP server is:
First of all you have to download it throw the official web site i advice you to download the last version to have the latest version of Apache server phpmyadmin and MySQL and not the beta version because beta version cause errors and problems sometimes.
So after you complete the software download you have to run the installation file.
It will be install in C:/WAMP
Then go and connect the server.
It so easy just follow my instructions carefully and you are able to install the software in your computer.
Dear Bob,
The answer to you question and the solution is quite easy. The wamp server is basically used for mutiplexing your Apache, MySQL or PHP along with all releases. Assuming that you have the correct version of wamp server for your XP operating system, there are just few steps which are defied below in images. Please view all the images one by one and you will find what steps involved in it. Here going to explain wamp server 5 for windows XP. Hope this will figure out your problem and any confusion you have regarding installation of wamp server.
