How to install webcam windows 7
Hi there!
Usually, driver for the webcam is included in the operating system so it should run automatically after the OS has been installed but in rare cases, if it does not work, you might need to update the it by following the steps below:
1. Go to Start and click Control Panel
2. Click on System and Security and select the System tab
3. Click Device Manager and click on the plus sign next to Imaging Device to show selections and right click on USB imaging device or camera device and select Update Driver Software
4. Browse or search for the driver folder and make sure all folders are checked, click Ok and close the window then restart the computer.
Hope this helps.
