Hi guys, I want to know how to install whatsapp plus on android devices I know that any android smart phone is capablr of downloading Whatsapp but I liked the features of Whatsapp plus more than the Whatsapp as I saw this Whatsapp plus version in my friends mobile he uses Nokia X series thats why.But
please help me and let me know how to install whatsapp plus in my android smartphone and from where can I download it.
How to install Whatsapp plus on android phone?
You will follow the following to install Whatsapp in your Android smartphone;
Your Android should 2.1 or later
Security Settings > Unknown Sources [check the box]
Google > search WhatsApp Plus > download
File manager > downloaded file [for getting installation]
From this site (http://www.whatsapp-plus.net/download.php) you will get the latest version of Whatsapp. It is called v6.13. You may download it.
Hi, it is better to download and install official version of Whatsapp only but if you like and if you want to install whatsapp plus then search on google there are many web sites offering whatsapp plus download with links. You did not mentioned which hand set you are using so google search to download whatsapp plus for galaxy S4 this is just example as there might be different procedure for different handsets.Thanks
