Hi everyone! I am trying to install windows 2008 et oracle 9i for a couple of times already but it still didn't work. What should I do? Can anyone post a step by step guide here so I can easily understand the instructions? Any help will be greatly appreciated.
How to install windows 2008 et oracle 9i?
Hello Janice,
The best way to overcome the issues that you are getting when trying to install oracle 9i is to check the documentation and ensure that you are using the right steps. You may be missing some configurations options required during installation, for instance providing a username and password for the installation to be successful and therefore you will need to check that.
Nicke
