How to install Windows 7 home premium by acer key
I want to know the installation process of windows 7 home premium using the Acer key. Please explain clearly about it.
The installation procedure on any Acer or any other laptop is similar to normal windows 7 installation. The way you do the installation on other laptops the same procedure you need to follow. See the thing is companies doesn't follow any unique procedure for installing their branded OS rather they use a unique key which defines that the OS has from them.
As they buy licenses from Microsoft and distribute to individual user stating as Acer key but the installation procedure doesn't change. Only one thing can be changed the automating the installation procedure. Just insert the DVD in DVD drive and follow instructions. As simple as that.
The brand of your computer doesn’t change the windows installation process.
Follow the below steps:
Following article explains you how to change the boot sequence:
https://helpdeskgeek.com/how-to/change-boot-order-windows-pc/
Once the CD is loaded then it will automatically load the installation windows file. Then you just have to read the instructions and keep pressing next and finish keys until the installation process completes.
