How to Install Windows 7 From USB Drive
Yes of course you can use it to install Windows 7 from USB Drive or Flash Drive.Just make sure that you’re using GB memory it can save all the files you need to install your Window 7. And you’re ready to install it to your Computer. First thing that you will do is to restart and reboot. After rebooting press delete and it will appear an icon saying bios setup utility and go to the advance bios features you will see the following: the USB – HDD don’t enabled this or disable just remain it, the 3rd and 4th stanza you need to disable them then save and quit. After just wait the loading of the setup of the windows.
Ben
Hi H. Zeno,
To install Windows 7 from USB Drive besides these process you can get step by step system from this Techyv's page which will be easy for you.
Install Windows with help of USB
