How to install Windows in my netbook
Sometimes you need to give windows in your PC/netbook. But if you have not any DVD drive there will might create many problem. To give windows this time you face problem. You can't install your windows. First check your motherboard is able to reboot your windows by pendrive or not. Check by going into BIOS.
When turn on your netbook press F2 or delete button to go into the BIOS. Check that your netbook is able to reboot by pendrive or not. You can buy portable CD/DVD ROM. There are many companies that provide portable CD/DVD ROM. Buy a good portable CD/DVD ROM. Now, you will able to install windows in your Netbook.
Installation of operating system requires CD or DVD ROM drive or an optical drive. If you don’t have any optical drive in your laptop or notebook, you can use or create an installation on with your USB drive or flash drive. Creating of installer with your USB drive instructions is available in this site. Just search it on hear.
Or you may find also some tools for creating USB start-up disk by searching on Google. Another option is to purchase an external optical drives. There are external optical drives that do not support booting. Most of the external optical drives that support booting are those external optical drives having power dependent on the USB port.
