jones009
Posted on - 10/26/2011
Hi guys,
I have bought new Hp slim line desktop computer and I am thinking about that I can use windows XP small business 2002 version on it. But any one tell me about how can I install this windows on my computer and It will work properly. Please tell me as early as possible.
How to install the Windows Small Business?
Hi Jones009,
You should contact your nearest computer market to buy a genuine cd of windows XP small business 2002.
If you have not previously installed another windows on your machine then you can go on without any ado.
If you are currently using an operating system especially windows NT then you must clean the primary hard disk from the windows environment. (Make sure to back up your personal data first).
Before installing you should go into the boot menu to change the boot sequence in order to prioritize cd-rom to boot first.
Depending on your systems capabilities you can clean install windows with proper instructions available on the screen about each step.
Hope this might help you.
You most likely are referring to Microsoft Office XP which was the successor to Microsoft Office 2000 and came before Microsoft Office 2003. If you want to use this on your computer, make sure you install a version of Windows that came after Windows 95, as that version is not compatible with Microsoft Office XP.
All versions of Windows starting from Windows 98 up to the latest version which is Windows 7 should be able to work with this version of Microsoft Office. So get the computer set by installing Windows on it and then install your Microsoft Office Small Business 2002.
