I have a Dell Inspiron and I need to install WLAN driver into it so that I can use the internet. The internet is not working at the moment so I came here to ask for help. Where can I download the WLAN drivers for my laptop? It's 10 at night so I can't go to the vendor. Please answer ASAP.
How to install WLAN driver from the Internet?
To avoid the hustle of searching all over the internet for WLAN drivers, a driver management tool with simplify the work. Identify a driver management of your choice and download it. I prefer Driver Pac Solutions as it comes with a whole package of drivers you would need. You can download it here.
Alternatively,go to start menu-right click on computer-manage-device manger-right click on network and select update driver. Select search automatically for drivers, your computer will connect to the internet to find the WLAN drivers for your PC.
Since you have a branded computer, Dell, you can always download the driver for the Wi-Fi adapter from the manufacturer’s website. Go to Dell Drivers & Downloads to download. Here, enter your laptop’s service tag, serial number, or model number then click to search. You can find it printed on the sticker on the side or bottom of your machine.
When your product is located, click it to go to the download page. Before downloading, make sure your correct operating system is selected. If a different operating system is displayed, click to change then select your correct operating system. Download and install all available drivers and software for your computer specially the driver for the Wi-Fi adapter.
