How to Install Xp From Dos?
To start Windows XP installation from CMD follows these steps:
Start CMD. If your computer does not have MS-DOS already installed:
The MS-DOS based part of The Setup Program Is complete.
The Setup program will now restart your computer. After your computer restarts,
the Windows XP Setup program will continue.
To install Windows XP from DOS, use the following procedure:
Hello Dear,
Thanks for sharing your problem with us.
First boot your system from windows 98. After this go to CD ROM drive in dos, means if your CD ROM shows drive letter D then type "D:" and enter. First format your C drive. Type "format C:" and then press enter. It will format your hard disk.
Now type "smartdrv" and press enter.
Then type "cd.." to get off Win98 directory on cd.
Replace Windows 98 CD with windows XP Cd.
And type "cd i386" press enter then type "winnt" press enter.
Windows XP setup will be started.
I hope it will help you a lot.
