Bryan James
30 points
Posted on - 10/13/2012
Hello Experts,
How to install yahoo messenger for windows 7 starter? I need some download and installation process which is secured and virus free so that there is no way to harm my computer registry system, It is not easy to handle those viruses I don’t want to lose my important data and files.
Thank you.
How to install Yahoo messenger for Windows 7 starter?
Yahoo messenger is one of the popular programs in the internet in the means of communications. You can have a safe download of the program supported by Windows 7 in the Yahoo website. When visiting the page, you will see a download bar to be clicked, click it to download.
Once downloaded, an instruction will be given if you want to run the. Click Run and then click Ok. Wait until it is done. Afterwards you can now log in to your account.
You can download it in this link https://s.yimg.com/jd/desktop/0.8.288/yahoo-messenger-0.8.288-win32.exe.
Diane
Hi Bryan,
Yahoo messenger is one of the best means for communication on the internet.
It's really easy on how to download yahoo messenger in your windows 7 starter. Here are the following steps:
1. Go to https://www.yahoo.com/.
2. Click messenger ( found on the left side on their website).
3. Then click Download now. It's much safer to download yahoo messenger on their website.
NOTE: Downloading yahoo messenger depends on the speed of your internet connection.
4. After downloading a pop up box will appear then click RUN.
Note: Follow the instruction.
5. Log in with your correct Yahoo Id and Password.
Enjoy using Yahoo Messenger.
Hope this helps.
Robert
Hi Bryan James,
I have attached the links of some possible sites that you need to download Yahoo messenger for Windows 7:
You may also join the discussion on this site:
