I need this YouTube player Samsung phone, but i am not familiar with installing, so if someone could explain me how to install it on my phone?
How to install YouTube player Samsung phone ?
Hello Kenneth,
In order to play YouTube videos from your mobile phone's browser. You need to Install Adobe flash player for mobile first. Here's what you need to do.
Obviously you need to have internet access to do this.
Open your mobile's internet browser. I would suggest you open it from Opera Mobile. Other mobile browser software's seems to have problem with Adobe Flash for mobiles. Download and install Opera Mobile if you don't have it.
With your opera opened, Browse Adobe flash player for mobile by typing it in to your browser's index or address bar.
You should be able to see it in the list. Click download link and then install you only need to confirm the installation.
You should now be able to view videos from YouTube.
Hope this helps you.
Hi Kenneth Nickersonee,
Nowadays, youtube Players are available for any device may it be a Samsung, Iphone, HTC, etc. You only need to know which Operating System is being used on your phone. I know that most Samsung mobile phones are using android. If this is running an Android OS, you only need to download the Youtube app in Google Play. Google Play should be pre-installed in your android mobile. Search for Google Play on your Menu then open it. You will be prompt to register your gmail account. Once you have registered your gmail account, you can now search for apps. Type in the search engine 'Youtube.' Then you will see the app for youtube. Click on that to install. After downloading, enjoy browsing videos from your Youtube app.
Hope this helps.
