How the installation de msn
Hi ,
I want to use msn messenger. But I have no knowledge what steps perform during installation de msn please help and tell me what steps perform during installation of de msn.
Hi ,
Hi Halin,
Here’s the instruction on how to install MSM Messenger.
First, go to MSN’s website. Click the Messenger link (it takes you to the download page). Click button from the link that says “Download Windows Live Messenger” or “Download” to start the download. Next, Choose features that you want like MSN toolbar then click “Install”. When finished, look forWindows Live Messenger set-up program. If you are going to save it in a folder and not in your desktop, see can’t see it so search for Windows Messenger on start menu and it should bring up the set-up file. Click the set-up file and to finalize the download, follow the onscreen instruction.
That’s it. Hope it will help you.
