carl gock 30 points N/APosted on - 06/22/2012
Hello, I have recently downloaded fifa 12 in my computer. But PS3 is not allowing the game to install in my pc, rather than showing a code like ERROR 80029564. I have searched some forums where I found this problem but didn’t get the answer. Hoping for some help from you. Thanks.
Remember if you have FIFA 11 installed in you PC then FIFA 12 will not be installed.
At the time of installation of FIFA 12, this error code is normally displayed if the file You are trying to install is corrupted. But if you find that the file is not corrupted then try this :
> First check your hard disk drive that its got enough space to install the content. If its already got enough space then try and updating PS3 to firmware 3.73 via USB could help complete the installation.
Or if the file of FIFA 12 you try to install is corrupted then try this :
> First delete the old file then download it again from the PS store, and try again to install. Hope it will work successfully.
In North America, FIFA 12 is called “FIFA Soccer 12.” It is the 19th game in Electronic Arts’ FIFA series developed by EA Canada and published by Electronic Arts worldwide under the EA Sports label. Since you are only installing a game, it shouldn’t require any additional prerequisite applications to work like Microsoft .NET Framework and or Microsoft Visual C++.
If you are installing FIFA 12, first, make sure your computer meets the requirements. FIFA 12 supports Windows XP, Windows Vista, and Windows 7. It requires 2.66 GHz Intel Core 2 Duo or equivalent AMD Athlon II X2 245e or faster processor, 1 GB RAM, and NVIDIA GeForce 6800 or ATI Radeon X1600 or better video card.
The game does not support Windows 8.x and Windows 10 but you can try it but just don’t expect that it will run automatically. If you fall short on the requirements, you need to upgrade your system.
Lead generation and demand generation are two of the business strategies that help businesses grow. It creates a pipeline of interested customers looking to find out more. Lead generation on the contrary, is able...
1....
