How is an interactive carousel related to html5?
How is an interactive carousel related to html5 and what are the feature of this software? Can this be also related with actionscripts? Tell me more about interactive carousel and the its corresponding use. Thank you
Answered By 0 points N/A #150205
Interactive carousel is made up of jquery and HTML,Jquery won't work without the HTML, HTML5 is now widely use in the internet and supports almost if not all browsers whether mobile or  PC..
Actionscript is an objection oriented language owned by the great Adobe Systems Inc. Bought from Macro Media Inc. Jquery is an Open Source client side scripting language it's a javascript library. Created to minimize the frustration in creating complex syntax code. It can not talk to the server. Its main purpose is interactivity.
Actionscript and Javascriipt are related because both of them came from the native ECMA script. So it is not difficult to learn one script when you already knew the one.
Hope this simple language helps you.
