How the iolo Live boost work
I have tried looking up the internet for information on the iOLO live boost but I cannot find enough. I need to know what benefit it adds to a pc and whether it is necessary. If you are experienced on the same, I would be glad to hear from you.
Answered By 0 points N/A #187167
LiveBoost technology provides ability of a computer to provide faster response to the operating system and the program. This improves the performance of the Central Processing Unit (CPU), RAM and the Storage Drive to improve the system speed overall. The speed of any computer depends on the performance of CPU, RAM and storage drive. If any of these performance is degraded then the overall performance of the PC will be affected. IOLO LiveBoost is the application which will ensure that CPU, RAM and storage drive giving their best performance. It will make your PC faster this is the benefit of using this.
Although it can provide faster computer PC but usually it does not work properly. It sometime even crashes you operating system. IOLO is working continuously to improve these issues. You can give a try to use IOLO LiveBoost if you want.
