mon47
Posted on - 11/29/2012
I have recently bought an iPhone 4 schematic mobile phone. I was charmed using this type of BlackBerry iPhone. But a few days ago it was not charged fully and writing about iPhone 4 schematic had vanished. Is there anyone to whom I would be grateful for giving me the solution of the problems
How iPhone 4 schematic phone could be assemble and fix suddenly?
Your problem is critical but you can solve this problem by checking setting system . You can also doing restarted your phone.  To solve the schematic problem you have to check your setting .If you do not understand your setting option .
In this situation I think the better way is contact with iPhone customer care . But you know that you do not clearly describe your kind of problem . You can also visit an iPhone site . There are many websites to help you.
Thank's.
