How Is It Helpful – Microsoft Lumia 540 GSMArena?
I want to buy Microsoft Lumia 540 and some people suggested me to refer GSMArena. Is GSMArena some sort of app which compares the prices? How is it helpful, Microsoft Lumia 540 GSMArena?
GSMArena is a website which provides you the best reviews for your product and gives you all the necessary details related to it. If you google, Microsoft Lumia 540 GSMArena, you will find all the specifications related to your smartphone right from its launch date. It provides you all the necessary details, its specifications, its configurations, its reviews, its ratings, etc.
Lumia 540 is a dual SIM Smartphone. The Microsoft Lumia 540 Dual SIM is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on April 2015 and released on May 2015 measuring 144 x 73.7 x 8.6 millimeters and weighing 152 grams.
It uses dual micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch featuring ClearBlack display. It runs on Microsoft Windows Phone 8.1 with Lumia Denim powered by Qualcomm Snapdragon 200 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB.
It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 8 megapixels with f/2.2, 28mm, LED flash, and autofocus featuring geo-tagging and 1/4″ sensor size. It supports 480p video recording at 30 fps. The secondary camera supports 5 megapixels and 480p video recording.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 4.0 with A2DP support, GPS with A-GPS and GLONASS support, FM radio, and microUSB 2.0. It has built-in accelerometer and proximity sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on removable Li-Ion 2200 mAh battery with standby time up to 576 hours both on 2G and 3G. Talk time is up to 26 hours on 2G and 15 hours on 3G. It is available in orange, black, gray, white, and blue colors.
