How Is It Helpful – Microsoft Lumia 830 GSMArena?
I want to buy Microsoft Lumia 830, and some people suggested me to refer GSMArena. Is GSMArena some kind of app which compares the prices? How is it helpful – Microsoft Lumia 830 GSMArena?
GSMArena is a website which provides you the best reviews for your product and gives you all the necessary details related to it. If you google, Microsoft Lumia 830 GSMArena, you will find all the specifications related to your smartphone right from its launch date. It provides you all the necessary details, its specifications, its configurations, its reviews, its ratings, etc.
GSMArena.com is not an app but a website that creates reviews of popular Smartphones and other Smart devices as well as compare their prices. The Nokia Lumia 830 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies.
It was announced to the public and released at the same time on September 2014 measuring 139.4 x 70.7 x 8.5 millimeters and weighing 150 grams. It uses nano-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display.
It runs on Microsoft Windows Phone 8.1 upgradable to Microsoft Windows 10 powered by Qualcomm Snapdragon 400 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 305 GPU. It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 16 GB internal storage.
The primary camera supports 10 megapixels with f/2.2, 26mm, 1/3.4″, Carl Zeiss optics, OIS, LED flash, and autofocus featuring panorama, PureView, geo-tagging, and face detection. It supports 1080p video recording at 30 fps with stereo sound rec. The secondary camera supports 0.9 megapixel and 720p video recording.
It supports 3.5-millimeter jack featuring Dolby Digital Plus audio enhancement and active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS, GLONASS, and BDS support; NFC; FM radio; and microUSB 2.0. It has built-in compass, proximity, accelerometer, and gyro sensors. The pre-installed web browser supports HTML5.
Java is not supported. It runs on removable BV-L4A Li-Ion 2200 mAh battery with standby time up to 528 hours and talk time up to 12 hours 54 minutes on 2G and 14 hours 48 minutes on 3G. It is available in white, black, orange, green, and gold colors.
