How Is Windows Server 2003 To 2008 Migration Done?
I am thinking to change Windows Server 2003 to 2008 version. How is Windows Server 2003 to 2008 migration done?
Like other Windows editions, we cannot update and migrate to Windows Server versions directly. To migrate from one version to another, it is always better to adopt the licensed copy of the versions. We can also download the next version from the Internet provided we opt for the safest download.
To migrate to Windows Server 2003 to 2008 directly on the computer,
• Click on the Start Menu and click on Run.
• Type wuauclt / detectnow in the command prompt and press “Enter.”
• If there are updates available, a yellow shield will appear in the same place. Double-click on it and follow instructions for installing the updates.
• If Server 2012 version is available, it will ask for the update.
• In the case of Windows Server 2003, Migration Tools support Server 2003 with Service Pack 2 and Server 2003 R2 operating systems.
• Both can migrate to both Windows Server 2008 R2 and Windows Server 2012 R2 with the 64-bit processor.
Notifications
