How is it possible to stop search history of Windows7?
I am a Windows 7 user and surf internet all day long. I share my PC with some of my family members but I don't want them to see the websites I browse.
Please suggest me the way out of it.
Hi Andi,
Hope the following steps will guide you in fixing this issue.
Hi there,
Definitely it possible to stop personal web history in Windows 7. Your problem is blocking the web history so that none can see what you have browsed earlier right?
The solution is simple, Just follow my steps carefully and precisely:-
1. Open internet explorer.
2. Click on the wheel like button on the extreme top right of your browser (settings button).
3. Go to internet options in that drop down menu.
4. In that general tab make sure you tick "delete browsing history on exit".
5. Click on delete button and click on the respective button to delete all history.
6. Now you are done.
Notifications
