I have been taping footages for my research project.
I want to collate all the recorded videos into a single presentation only.
The videos were recorded with my canon digital camera and the format is mp4.
How do I join mp4 clips together?
Would merging the video affect the quality?
How to join mp4 clips together?
Hi Hargrave Lawrence,
You can use the Adobe Audition in order to join two or more clips of mp4 and then render it.
To use it, download the Adobe Audition in your desktop on Adobe.com and then open it. You have to import music files to join and then drag it onto the timeline, locate the ending of the first one and then drag the other music file at the end of the first file. With this, you have successfully joined two music files into 1 music file, if you wish to save the project file, please go to File > export or Ctrl+E.
There are many software solutions to complete this task. Following very common software may be used to get required results.
1. MP4 Joiner is a good software may be downloaded from this link http://www.dvd-tool.com/mp4-joiner.html. It joins a number of media file formats including MP4 and MPEG4.
2. Windows Movie Maker is another very good solution to join multiple MP4 files into one.
3. AVidemux is another free and a good software to do this task. It supports multiple file formats to convert as well as to merge.
Following steps may be taken to merge MP4 files into One.
I. File >Open > Select File
II. File > Append > Select File
III. Set All to copy
iv. File > Save > FileName
The user has had to wait for some time to complete the process.
This software may be downloaded from following links.
1. https://sourceforge.net/projects/avidemux/
Hi Hargrave Lawrence, in addition to answering your concern about incorporating your mp4 clips to create a movie, mp4 compiler by softonic can also be a great help as well as mp4 movie joiner.
I always believe that each of us has our own unique preferences that's why I am providing some alternatives.
Enjoy.
