How to join multiple jpg images into one PDF?
Hi ! I have got chunk of jpg images to be sent through mail in simpler form.I was wondering if there is any free software to join multiple jpg images into one pdf.I have downloaded two-three but they are trial versions.Please suggest any full version freeware to complete this task.Thanks.
Answered By 0 points N/A #154869
When you add your images to document in word, Powerpoint or other, you can add multiple images to one word/ powerpoint page in your document.
First, in MS Word 2010 you can click on Add image, and then repeat this step for number of images you have.
Second, you need to download PdfCreator Freeware 1.6.1.
Third, in your Microsoft Word document you have an option to print your document using different printers. 1)Select file, then 2)print, 3) print to PdfCreator, and this command allows you to save your image as pdf file, where your images are ready to be send in a compressed PDF format to others.
