How to keep track on registry change in a computer?
I am using Windows 7. How can I keep track on registry change on my computer? Is there a way to do it? What application should I use for me to track the registry? Can you tell me where to download it? Thanks a lot.
Best Answer by WilsonJames
Answered By 0 points N/A #150780
There is a tool which you can use to keep note on changes of registry. RegSnap is a program that takes note whenever there are changes in you Windows Registry. It works by exploring the pictures that it took and you can compare them if there are changes. It has tons of features which you can explore after installing it. You can download it at https://www.download3k.com/System-Utilities/Registry-Shell-Utilities/Download-RegSnap.html
Answered By 0 points N/A #150781
Hi Sabrina,
Download “Process Monitor” which is a sophisticated tool that can be used to monitor system operations in real time.  It Monitors Registry, Processes and All System Threads in Real-Time. You can download this software from https://docs.microsoft.com/en-us/sysinternals/downloads/procmon for free.
Some of its capabilities include:
  1. Allows one to set filters without losing data
  2. Accurate capture of process details
  3. Has advanced logging architecture
  4. Can display the boot time logging of operations
