How To Know Compatible Graphics Card For My PC?
I want to play some high-resolution games on my PC and for this, I need to install a graphic card, but I don’t know which would be the compatible graphics card for my PC?
It is crucial that you buy a graphic card that can work with your Existing PC so that it gets fit properly in the slot. A PC can assist either ‘integrated’ or ‘dedicated’ graphics card. But in both the cases, you need to check for your PCI Express slot. For installing a NVIDIA or AMD graphics card, you need a PCIe x16 slot.
It is advised to use the most upper slot if you want to insert a single Graphics card. However, you can use both slots in case of two of them.
Now, check the details for power requirements on your graphics card And see if your power supply unit can handle it or not. If not, then you can use the support connectorto get the work done.
